Team voting using a Scale?
Is it possible to make a Scale as a means of voting? At the moment there is an upvote/like style option, which works for a lot of things. But I was looking to get team members to vote on a 1-5 scale using the Number > Scale column (and in an ideal world non-team members too, but I’d settle just for team members).
Is it possible to have a Scale row result not be set by one person but by many? I tried creating a form but that’s just for inputting a new row, not displaying existing and asking for votes.
Hello @Jonathan_Richardson ,
I also use sliders for voting :).
SwitchIf(thisRow.[Make an emoji slider]=5,"😎😎😎😎😎",thisRow.[Make an emoji slider]=4,"🙂🙂🙂🙂",thisRow.[Make an emoji slider]=3,"😐😐😐",thisRow.[Make an emoji slider]=2,"😣😣",thisRow.[Make an emoji slider]=1,"😱")
Sincerely,
Thierry
chrome_Kuf9Y5kZkF
Thanks @Thierryvm I’ve copied your code but does your work so that different team members can vote on it? For instance if I move the slider to 4 would it only record my 4 score, what if someone else logged in and moved it? Thanks
Indeed here the limit of this basic system is that anyone in the state could modify.
But if you define for example a column with the participants for example with a selection list for each new vote, the new voter should understand quite easily that he has to choose his row.
Another solution would be to use a form that links this table and then he should not be able to intervene on other votes.
If it doesn’t work as you wish, I will test it myself as soon as I have a little more time.
If not, I’m sure that some pro coders will come by here :slight_smile:
Sincerely,
Thierry
Translated with DeepL Translate: The world's most accurate translator
Hi @Jonathan_Richardson :blush: ,
For this, you could use a button and a table to store the votes :blush:
Here is a very quick sample I put together and as you’ll see the [Voting Table] is just a one row helper table where I have a scale, a button and a notes/canvas column to store all the votes :blush:
The scale is used to input the vote (from 1 to 5) so anyone can modify it… The button effectively save the vote in the table [All votes]. Then it resets the scale to its initial value.
The button Action formula looks like this :
RunActions(
  AddRow(
    [All votes],
    [All votes].Vote,thisRow.Scale,
    [All votes].People, User()
  ModifyRows(
    thisRow,
    thisRow.Scale,
And what it does is:
1st Action : AddRow() : It adds a row to the table [All votes] with the following values:
  • In the column Vote, it adds the value of thisRow.Scale
  • In the column People, it adds the current user (User()) … if you need it :blush:
    Another way to add the person who voted would be to use the table property Created by (But as I still only have one Coda Account, I’m enable to test this fully :innocent: … Same goes for the button :blush: )
2nd Action : ModifyRows() : It just modifies thisRow.Scale to get it back to its initial Blank ("") state :blush: .
I’ve also added a Disable if formula to disable the button if thisRow.Scale.IsBlank() (to avoid blank votes)
And then, there’s a simple Average column to calculate the average (:sweat_smile: ) of all the votes :blush:
You could also do something similar using the Canvas :blush:
Those are just ideas :blush: … But I hope it helps :blush:
Hello,
Indeed Pch, your approach is much better than mine :).
Sincerely,
Thierry
@Thierryvm : It’s not necessarily a better approach :blush: . Just a different one.
Using a form would be a way to do it… It’s just that @Jonathan_Richardson mentioned this :point_down: in his original post :blush:
So, as it seems that forms were out of question, I simply shared other possibilities :wink:
thanks both, both are useful ::
