Text column is being treated as number in formula
I have a column full of IDs.
0108
0109
0110
And it is a text column because they aren’t really numbers one would do some calculation with, and I need that 0 to remain there.
In another column, I applied the formula ID + ".png" but got 108.png instead of 0108.png. See gif
I worked around it by using CONCATENATE formula.
Thinking about it, maybe this is a feature (like coda trying to guess what I’m trying to achieve with the plus sign operator). But I’ll leave it here in case someone has the same problem.
Google Chrome - Untitled doc · Untitled page 2023-10-30 às 16.02.12
Compose column also respects ID column type and gives me 0108.png as result.
Can you please add your vote here:
Thank you for pointing that out! I’ll delete this post
the problem is in using +
ID + “.png”
Coda Formulas are converted to Javascript under the hood, and Javascript does some really nasty type conversions with operators.
Solution: use concatenate() instead.
