Text find and replace
It would be enormously helpful in constructing documents to have find and replace. Even if it only works on text initially. If this feature already exists, I can’t seem to find it anywhere :stuck_out_tongue:
Hi @anon16319774!
Does RegexReplace do the job?
RegexReplace("Top Flat w/Parking (marina / cow hollow) $1200 1bd 800ft", "([$]\d+)", "$2000")
Returns
“Top Flat w/Parking (marina / cow hollow) $2000 1bd 800ft”
If learning/using regexes (regicies?) is not your thing you can also use Substitute which is simpler but less powerful.
Substitute("Hello world", "Hello", "Good morning")
Returns
“Good morning world”
thanks for the suggestion! that works for transforming columns in a table, but I’m not familiar with how that can apply to text as paragraphs, headers, code blocks, etc. outside a table column.
Ahh I see what you’re saying. I’ll play around with something and see what I can find
What is your goal with using find and replace? Are you looking to make a dynamic document, or are you just trying to fix errors on your page?
more like fixing errors. in my particular case, I’m writing a design document and my team has decided to rename something. Instead of searching for each occurence in the search bar, and manually replacing, I would like to specify the replacement.
Basically this feature from gdoc:
Ah yeah, that would definitely be a nice feature to have. For now, you might be able to use something like this chrome extension to get the job done.
I totally agree to have this feature
This extension does not work with tables.
Find and Replace is a must-have tool for any document editor. It’s strange that it’s not in Coda yet
This is a pain point.
Working on live docs in an evolving design space, names and terms change all the time.
Having a way to simply change them anywhere they appear in text is … I mean… it’s kinda basic, isn’t it?
i totally agree - its a HUGE missing piece for a product that is aimed at note-taking and text-based collaboration
i wish i could give it more than just ONE vote
for now, i copy/paste the pages text into another tool and do my find/replace operations there and then copy/paste the page back
but i must do that in sequence for EVERY page in my documents!
max
hi @Max_OBrien ,
the moment data is living on a canvas in tables, we might consider a regexReplace(, , )
wouldn’t this solve most of the issues you face today?
cheers!
Christiaan
@Christiaan_Huizer - could do but…
what we need is a global search/replace built into the document UI
and not have to create and code special buttons or formulas
i have a workaround like that in progress for an auditable document
but - i had to replace the whole page canvas with a large view of a table row
(a single cell containing a canvas column type)
thats because, i can ‘grab’ the contents of the canvas using ToHtml() and then use RegexReplace() on that - but there is no way to get the modified text back into the page canvas!
so my workaround for the workaround is getting very convoluted indeed
max
+1 for this feature request
Also be nice if find/replace could work with partial words - like replace ABCDE in ABCDE23451 with FGHIJ to give FGHIJ23451…
even with the new AI assistant, this is a miss. Still need this feature
+1 for this FR. Thanks!
yes, Find and Replace is "table stakes"functionality in any word processor, which—let’s face it—Coda.io is a web-based word processor on steroids. Without this, we’re still using other tools, and so adoption will be low within any given org.
Shocked this feature is not available. I am using Coda to co-write a book. So no text in tables. This is making me feel like I made a mistake suggesting we use this app :frowning:
What kind of information management tool does not let you find and replace text ?!?
Please address this!
