Toggle between table and calendar views
I’ve been searching for a way to create a toggle control that will change a view to display as either a calendar or as a table depending on the toggle status. Is there some way to do this?
For context: I’ve created a task manager for our team using Coda and I want to make it easy for them to see their assigned tasks in a table view or in a calendar view without having both views visible and taking up space on the page. Right now, both views are present and they have to collapse or expand each one in order to view it without both of them being expanded at the same time.
I am also interested in this possibility, I will keep an eye on the topic
Hey Shaina and Dima! This is actually going to be a feature request. We’ve gone ahead and logged your interest in our Feature Request Tracker which our team regularly reviews. Should this be built out, or team will reach out to let you know :+1: Thanks for sharing this idea with us! :star_struck:
Tabbed views are now available! You can set up a table view in one tab and a calendar view in another, switching between them instantly without expanding or collapsing.
Read the full announcement here.
