Hello,
I’m sure I’m not the only who has requested this very basic and simple feature of an effective Kanban board.
Yes there are workarounds by using a control but it’s does not help when one wants to move a card across columns and rows.
Thx
Ratish
Ben_Lee
2
Hi @Ratish_Gupta,
You can drag and drop cards between columns. If you change the view back to a table, you’ll see that all values were updated accordingly too!
Have you see this help article?
https://help.coda.io/en/articles/1184783-how-do-i-create-a-kanban-board
Let us know if you were referring to something else or if we can help you our further!
Ben
Yes, I can drop cards between columns but I want to move cards across rows and columns simultaneously.
I have over 250 cards and around 15 teams.
Ratish
Ben_Lee
4
A card is a row, so if you need to change values in that card/row you do need to open it and change the values.
You can always create a view of the table and have one in table view where you can highlight a column to paste values in bulk.
If you have a sample doc you can post, we can try to help you out with it.
