Trim() method is deleting integers from strings created using format() method
Bug:
The trim method is deleting integers instead of whitespace from string created using the format method.
How to Replicate:
When inserting an integer into the beginning of a string using the format method, a subsequent application of trim will remove the integer.
Expected Behavior:
Only whitespace should be removed, not the integer.
Example: Trim Error
Hi Christian,
Thank you for the bug report, We have this bug in our internal tracker and our team is working for a fix.
Soon they will be releasing a fix for this.
Stay Tuned!!
