I am trying to format a number 15,000,000 to 15M. This issue I am having is that when I try to create a column that does this 15,569,245/1,000,000 the result is 15.569245 which I then want to format as just $15.6 M. I am doing this in two steps currently.
Col A 15569245/1000000 , then set the column formatting to numbers with 1 decimal.
Then in another column i concatenate ("$", ColA, “M”)
Is there a better way?
Hey @David_Baca I would add Round() or RoundUp()/RoundDown() to get your 15.569245 to 15.6, then use Concatenate():
Concat("$",Round([Col A],1)," M")
Good luck!
I did try this but I get a wrong argument type error.
Round expect parameter number to be a number , a formatted number, a percentage or a currency amount but found [ColA] which can match a column or a list of number
I forgot to mention that ColA has a filtered formula/lookup column
Hi @David_Baca
there are two possibilities, depending on your lookup filter.
- [row data type] It’s a single result but you need to access the relevant column of that lookup table. Such as
[Col A].Amount
- [list data type]: your filter already takes the relevant property, but there are more results (even if it’s displayed one). In that case you should either narrow (
First(), Last(), Nth()) or aggregate (Sum(), SumIf(), …) the filter in order to have only one value.
Having a preview of your filter would help
Anyway: let me know if this helps.
Cheers!
It was a list data type Once i entered in the .first() it worked like it should. Thanks!
