I’m working on a complicated doc, and the best solution I can come up with for a complex issue (don’t ask me to explain), is to unhide or move a page on a button click. Is there a way to do that?
sorry to disappoint you @Craig_PaxsonTN , but we cannot reference the hide or unhide status of a page. I am afraid you have to review your data architecture. cheers, christiaan
Hi @Craig_PaxsonTN,
there is a pack that can make a page visible and hidden.
I haven’t tested it myself, but feel free to check if it suits to your use case.
Best regards
Jannis
I’ve created hidden pages and then link to them inside of a button. The user is sent to the page whether it is hidden or not. I use this for forms where I want to set a bunch of values via other buttons and then send the user to the form. Not sure if this will help your situation or not.
Thank you! I think I found the workaround I need.
