Unique values in new rows
I am guessing there is a simple solution out there and I am driving myself crazy trying to find it. Anyway, I have a massive table with a Customer Name field… each customer name could have hundreds of rows associated with it.
In another table, I am trying to list the unique customer names. I can use the “sourcetable.customer_name.unique()” equation to capture the unique names in a list, however, splitting the names into rows is proving to be challenging.
I saw someone used an approach like “sourcetable.customer_name.unique().formulamap(addrow())”, but that is erroring out on the addrow piece.
Any ideas? Feels like this should be a simple solution.
Hey @Eckles_Brock
Here is a quick solution to create/update your customer list
Here is my initial situation : a Table with transaction including the customers you want to extract, and a Customer Table
Firstly, I check if the customer already exist in the CUstomer table (this is for further update)
Then, I’ve got a button that will create unique row in CustomerTable for customer that does not already exist → this allow initial creation but also update
And here you go
CPT2310092140-1154x721
Please find embed and play with it
Cheers
Quentin
Great, thanks!! Really appreciate the help!
Hi Eckles,
What you could also do is to follow the following steps:
  • Make the customer column a Select column type.
  • And then go to the column options, and choose the option “Convert to table”.
