Alright - Lets talk notifications. I don’t know about others, but they have at times seemed unreliable to me (sometimes they trigger, sometimes they don’t, some methods of notifying go to spam, others dont, some take 1 minute, others take 10, etc.)
Anyways - Im finding an unreliable notification automation in one of my docs, and I just can’t figure out whats causing the problem. My current theory is: If a row is updated/changed by automation bot, these kinds of changes are not caught/read by other automation triggers as row changes and thus do not trigger those other automations.
Here is how its running right now:
This notification has been working in the past, and has records of successful activity. I also have confirmation from those who have received the notifications that they are indeed working.
All of a sudden today they decided to not trigger correctly. The if condition read the result of step 1 as false and stopped the notification which led me to believe there was something wrong in my tables. I checked and double checked my tables (and did not change anything in-between them working correctly and then not working correctly) and the if condition should have read true? But it read false?
I checked and double checked that row and Number is indeed = 2. Although in a deeper dive, I looked at the time that row (thisrow.number.modified()) was updated and by whom. It was updated after the original trigger time of 4:36 (see screenshot) and it was updated by Automation bot.
This leads me to believe that If a row is updated by Automation bot, other automations not pick that up as a row change in order to trigger a different automation? - is this true? Has anyone else run into this same issue? Because when my number column was changed at 5:03pm by automation bot, that change was not caught by my Notify VP automation in screenshot above. Any thoughts?
Thanks for the help!
(@Paul_Danyliuk any chance you can help confirm/deny this one as well? - Can’t figure this one out)
