I’d like to use the new Detail view on a table and be able to easily add a new row below the one being displayed. The workflow me and my collaborators have means “splitting” a row in two or more sometimes, and it’d be great if I could do this with one click!
Any ideas?
Hi William,
Interesting problem!
Here’s what I put togather!
document is here:
Here’s how it works:
For rows to show up in specific order, you have to apply some Sort to it. In the document I’ve linked I am using Category Number as a sort column.
Now, if we can generate a Category Number that is between thisRow and nextRow and assign that number to newly created record, the newly created record will automatically appear as a nextRecord. For example, if current row on which button is clicked is #5 and the next Row is #6, if we can assign, #5.5 to newly created row, it will appear in between. that is what the following formula does
if(Category.Filter([Category Number] > thisRow.[Category Number]).[Category Number].Sort().First(),(Category.Filter([Category Number] > thisRow.[Category Number]).[Category Number].Sort().First() + thisRow.[Category Number])/ 2, thisRow.[Category Number]+ 1)
if there is a next record, then it takes Category Number from that one + category number from current row and divides it in half (so in earlier example, it will (5+6)/2 = 5.5) - if the row is the very last row, then it adds 1 to CategoryNumber.
Hope this helps - would be happy to answer any questions (and would love to hear if other folks have different ideas)
Thank you,
Krunal.
Engineer - Coda.
Dear Krunal,
Thank you sharing this creative approach
and sharing in detail the steps
your created to deal with this challenge.
Many users including me will be able to learn a lot and being encouraged to find solutions for challenges that today seem impossible to overcome.
Thats whats Coda about, FUN
Thanks! It’s a beautiful solution Krunal, worked like a charm!
I like that it’s built to be flexible regardless of how many new rows are created.
wow @Krunal_Sheth, What a solution!
