Using Today() to populate cell
When I click a button I have defined which amongst other things, uses the Today() function to populate a cell in a table to today’s date, sometimes it works, other times I get yesterday’s date.
I have done a search and seen similar reports from 2018 and 2019 with a suggestion to add an offset of X hours with reference to my location. The thing is I am finding it is intermittent so I’m not sure it is an offset issue. If it was, surely I would consistently get yesterday’s date?
Since @Hung_Doan wrote this interesting article, I guess he can help you out :wink:
cheers, Christiaan
Dear @Rowan_Limb , welcome to the Coda Maker community.
The evolution of Docs/app is going on and currently you are able for each doc to adjust the settings to your preference.
I already have my region/timezone set correctly. And in any case, if this was wrong how would that explain that it is INTERMITTENTLY not working?
Dear @Rowan_Limb,
I suggest to contact support@coda.io to have a look on this subject.
It would be great if you could share the outcome, in case somebody else faces such error in the future, thank you.
