Summary
Navigating across time ranges in Timeline View requires double-scrolling when lists are long (scrolling vertically to reach the bottom horizontal scrollbar, scrolling horizontally, and then scrolling back up). Updating the viewport behavior or enabling canvas panning will significantly improve navigation speed and user experience.
User Story
As a user managing large, active projects with high item counts,
I want to scroll horizontally across the timeline at any vertical position,
So that I don’t lose context or have to constantly scroll down to the bottom of the page just to change my date view.
Current Friction / Problem
Hidden Scrollbar: The horizontal scrollbar is anchored to the bottom of the entire container content, rather than the bottom of the user’s viewport.
Loss of Context: When a list contains dozens or hundreds of items (extending past the screen height), users must:
Scroll all the way to the bottom of the page vertically.
Scroll horizontally to the target date range.
Scroll all the way back up vertically to locate their specific task/project.
Proposed Solutions
Option A: Sticky Viewport Scrollbar
- Anchor the horizontal scrollbar to the bottom of the visible screen (viewport) so it is always accessible regardless of vertical scroll depth.
Option B: Click-and-Drag Canvas Panning
- Allow users to click and drag across empty areas of the timeline canvas (or
Shift + Drag/Middle Click) to pan horizontally and vertically freely.
(Bonus) Shift + Mouse Wheel Scrolling:
- Support
Shift+Vertical Scrollto trigger horizontal navigation.
- Support
Expected ROI & Value
Efficiency: Eliminates repetitive 3-step navigation for every timeline inspection.
Consistency: Aligns Timeline View with standard industry tools (e.g., Gantt charts, Figma, Miro, and modern board views).
High Frequency Impact: Fixes a daily micro-friction point for high-volume users and team leads managing large portfolios.
