View on phone not the same as on desktop
Hi,
Tricky to explain but I have lots of tables on my coda doc and they are collapsible.
When I view the document on my phone one of the tables is uncollapsed even though I left it collapsed on the desktop version and closed Coda like that prior to opening it on my phone. Is there any way I can fix this? I want it to look good when others open the document.
Thanks
Hi @Charlotte_Fisher , thanks so much for reaching out about this! If you feel comfortable doing so, we would love for you to share your doc so we can give you some advice. If you’re unable to share your doc publicly, we recommend replying with some screenshots showing the less than desirable view on mobile vs. desktop. Look forward to hearing from you!
