Hi,
I have been tinkering with Coda AI since I got it.
Is there anyway to have a button trigger AI component on a page or in a table?
Hi,
Hey @Chen_Zhong,
Great question. We would need to know more about what you are trying to do with this use case. If you have a doc to share or want some closer insight, I would recommend reaching out to support!
Hope that helps.
Sure!
So currently if I have a canvas AI component to summarize a view of a table, where I have a bunch of canvas control filtering the view, whenever the filter is updated, I have to manually click on the component to regenerate, which is not so good interface-wise. I want to build a doc for others to know clearly where to click and what to expect.
This is something that’s been on the teams mind a good bit. It’s trickier than it sounds because buttons are really powerful and you could end up writing a button action that takes tons of AI refresh actions on a large table.
So it’s definitely on our radar, but is still might take some more research.
