Hello,
I’m making a new coda and wondering how could it be possible to count the number of occurence the reference to a table line appear in the entire doc as “link to row”.
I’m using links to row and I wanted to know how many times a link pointing to a row.
Thanks to all of you, and Happy new year
Dear @Benjamin_Athlan2,
Welcome to the Coda community
Would you mind to share a dummy version of your doc?
Depending on the set up, it shouldn’t be to difficult to help you out.
Hi @Benjamin_Athlan2,
The closest we can get to counting the actual formula references made for a row would be in the “Doc Map” area in the settings. Click the gear icon at the top right of your doc and you’ll see Doc Map in the right column. There isn’t a formula to count formulas.
