What Should I Be Using For If(Value.isNotBlank(), ..., _NoOp())
It’s pretty common that I need to write a filter like:
If(categorySelector.isNotBlank(),
  [My Table].[Category].Contains(categorySelector)
  _NoOp()
This strikes me as an ugly pattern, however I don’t know a way to get around it.
I know how to handle the opposite:
categorySelector.IfBlank(...)
But there is no IfNotBlank formula. Also, _NoOp() is technically not supported, even though I use it in every doc at least 20 times. Anyone know a more elegant solution?
@Paul_Danyliuk? @Federico_Stefanato?
I guess I’ve asked about this before on my other account a couple times, haha.
Hi @cnr ,
I second you: it’s not the best pattern ever and I use it a lot, too.
I didn’t find any better alternative, yet.
While not super-urgent, I’d like to see some shortcuts of else-less-if(s).
Something like DoIf() or DoUnless() (or naming variations like RunIf() etc…) that consider the default action is a _Noop().
Happy to know your idea on this, btw.
Cheers!
Hi,
New here and no expert - so I could very much be misunderstanding your question. but isn’t it as simple as writing the following formula in your filter:
categorySelector.isBlank() OR [My Table ].[Category].Contains(categorySelector)
the OR operator means that the formula will always return true if the categorySelector is blank and thus the table will not filtered in that case. You can use a single formula to filter based on multiple controls using the same pattern and and outer AND operator:
someSelector.isBlank()
OR
[My Table].[someColumn].Contains(…)
AND
anotherSelector.isBlank()
OR
[My Table].[anotherColumn.Contains(…)
Hi @Nad ,
and welcome to Coda Community! :handshake:
You are right and this actually let me understand I misread @cnr’s first post.
As a matter of fact, composition of conditions - as complex as you like - should allow to have a unique boolean output.
(@cnr: are we missing something, here?)
I took it for another anti-pattern I keep on running into, which is conditional actions:
If(<condition>, RunActions(...), _Noop()).
This is the only way to achieve it, so far and it’s quite ugly to my sensibility :slight_smile: without even taking into consideration _Noop() formula isn’t official.
Thank you!
@Nad, great point!
Is an elegant solution. I’d still argue that someSelector.ifNotBlank(...) is a bit more readable, but I’ll be using your approach until we have that.
@Federico_Stefanato couldn’t we use SwitchIf(<condition>, RunActions(...))?
Seems to work here.
Edit:
The only reservation I have about this approach is that I find it more complex to parse at a glance what a condition is doing when it contains many OR and AND tokens. I suppose with some formatting it’s a bit more readable.
  OR
AND
  OR
  [My Table].[anotherColumn].Contains(…)
If logical operators could be chained then this might be an interesting pattern. Not sure it’s much more readable but at least operator preference is explicit.
  someSelector.isBlank().Or(
).And(
  anotherSelector.isBlank().Or(
And you are right @cnr! :+1:t2:
I was convinced SwitchIf() had a non optional default.
Thanks for this! I’m new-ish to Coda and having from the drudgery of Excel, I had gotten myself used to accepting long horribly unreadable formulas, since excel doesn’t accept any formatting. I’m very happy to see just now that Coda’s formula editor preserves formatting - Yeay !
I think it used to, I’m sure I’ve tried it before. But maybe they changed it.
Yeah! It’s great. Thanks again for improving my approach!
Would you be interested in collecting:
  OR
and
into a single answer and I’ll mark it as your first solution in the Coda community? I think it would be useful to future readers to have them all in one post.
