What's the difference between Switch and SwitchIf?
I’ve always used Switch when i’ve coded on Java/JavaScript/etc, but here, i’ve tried to use Switch as usual and it didn’t work as usual, but SwitchIf does, and after reading what it’s supposed to do, i didn’t understood it.
Could someone ELI5?
Hi @Pedro_Jimenez ,
are you familiar with the formula documentation? It’s explained there.
In SwitchIf, every “argument pair” needs a condition first that is either true or false.
Switch on the other hand has an expression, like a variable, as a first parameter followed by the “argument pairs”. Each argument pair starts with a value, if this value matches the expression, the condition is true.
SwitchIf is like if else if else... Use it instead of nested If(expr1, ifTrue1, If(expr2, ifTrue2,...))
Switch is take an input and compare it strictly to values. Use it e.g. for returning different things depending on a dropdown value (e.g. [Task status].Switch("Done", ...))
JS CFL
image image
And
Value.Switch(
  "val1", do1,
  "val2", do2
is like
SwitchIf(
  Value = "val1", do1,
  Value = "val2", do2
Hi @Paul_Danyliuk @M_Schneider
Thanks for your replies, i felt so confused that i couldn’t think clearly! But now it’s clear, thanks for the help!
