When printing a page with images, images are not correctly sized
Hello everyone,
I’m trying to export a page in which I have images, the page has a layout narrow, and when I look at the page it looks fine :
But when I try to export the page then the image taks a more size than the A4 page.
Does anyone knows a way to have correct export ?
Thank you
Here’s the result after export
Hello,
Has anyone an idea here ?
hi @Thoma_Bigueres2 ,
I am afraid that none of the volunteers active in the community can help you here. This is something for Coda HQ to sort out. Questions about print (to PDF) have a long history and although small steps have been made, we are still waiting for the big step forward to reuse the content of our docs via a printed pdf or as a simple print.
Did you consider to reach out to support via the question markt down right to have them answer your question?
Cheers, Christiaan
I could not reproduce the issue. Can you share a dummy doc?
Hello everyone,
Thanks for your answers !
@Pablo_DV by trying to do a dummy doc i’ve realised that the use case might not be “standard”.
I have a table in which I have documentation.
I want to export all the documentation and to do so I create a page in which I have a formula.
Here’s the dummy doc :
When playing a bit, I’ve found out that if I actually do a resize of the image in the original canva, it works ! but If I don’t resize, then it doesn’t work !
I’ve actually added another page where we can see the expected result !
In the first page coming from a formula :
  • Images can be cut in half
  • If no resize of the image the image is trying to set full size
In the second page where I’m using directly the canva :
  • Images are not cut in half, a page jump is created
  • If no resize, the image is correctly resizing itself !
I was going to play/propose playing with the image() formula with specific dimensions if the default didn’t work. But glad you figured it out yourself!
