For the past month, I’ve been unable to use Coda in Edge (131.0.2903.86 version). Navigating to coda.io the URL switches to https://coda.io/docs/ and the screen is all white. I’ve even logged in using a private window and I get the same thing. Looking at devtools, I get the following errors in the console:
background.js:12 application not running
(anonymous) @ background.js:12
o999875.ingest.sentry.io/api/6006079/envelope/?sentry_key=650ad5569e6b44168c6750dad16368a8&sentry_version=7&sentry_client=sentry.javascript.react%2F7.120.0:1
Failed to load resource: net::ERR_BLOCKED_BY_CLIENT
Refused to execute inline script because it violates the following Content Security Policy directive: “script-src ‘unsafe-inline’ ‘unsafe-eval’ https: ‘nonce-TXXa0ZZ8XWdg13Fye0/UlQ==’ ‘strict-dynamic’”. Note that ‘unsafe-inline’ is ignored if either a hash or nonce value is present in the source list.
docs:4 Refused to load the script ‘https://cdn.coda.io/assets/website.61e4e2d8c92ccb14fa25.entry.js’ because it violates the following Content Security Policy directive: “script-src ‘unsafe-inline’ ‘unsafe-eval’ https: https://.mutinycdn.com https://.googletagmanager.com https://cdn.cr-relay.com/ https://*.getkoala.com ‘nonce-TXXa0ZZ8XWdg13Fye0/UlQ==’ ‘strict-dynamic’”. Note that ‘strict-dynamic’ is present, so host-based allowlisting is disabled. Note that ‘script-src-elem’ was not explicitly set, so ‘script-src’ is used as a fallback.
docs:1 Refused to load the script ‘https://cdn.coda.io/assets/website.61e4e2d8c92ccb14fa25.entry.js’ because it violates the following Content Security Policy directive: “script-src ‘unsafe-inline’ ‘unsafe-eval’ https: https://.mutinycdn.com https://.googletagmanager.com https://cdn.cr-relay.com/ https://*.getkoala.com ‘nonce-TXXa0ZZ8XWdg13Fye0/UlQ==’ ‘strict-dynamic’”. Note that ‘strict-dynamic’ is present, so host-based allowlisting is disabled. Note that ‘script-src-elem’ was not explicitly set, so ‘script-src’ is used as a fallback.
docs:1 [Deprecation] -ms-high-constrast is in the process of being deprecated. Please see Deprecating support for -ms-high-contrast and -ms-high-contrast-adjust - Microsoft Edge Blog for tips on updating to the new Forced Colors Mode standard.
docs:1 Unchecked runtime.lastError: The message port closed before a response was received.
The resource was preloaded using link preload but not used within a few seconds from the window’s load event. Please make sure it has an appropriate as value and it is preloaded intentionally.
guidde.js:2
POST https://o999875.ingest.sentry.io/api/6006079/envelope/?sentry_key=650ad5569e6b44168c6750dad16368a8&sentry_version=7&sentry_client=sentry.javascript.react%2F7.120.0 net::ERR_BLOCKED_BY_CLIENT
(anonymous) @ guidde.js:2
add @ guidde.js:2
o @ guidde.js:2
_sendEnvelope @ guidde.js:2
_flushOutcomes @ guidde.js:2
t @ guidde.js:2
(anonymous) @ chrome-extension://p…eIframeService.js:2
add @ chrome-extension://p…eIframeService.js:2
o @ chrome-extension://p…eIframeService.js:2
_sendEnvelope @ chrome-extension://p…eIframeService.js:2
_flushOutcomes @ chrome-extension://p…eIframeService.js:2
t @ guidde.js:2
(anonymous) @ chrome-extension://p…kActionService.js:2
add @ chrome-extension://p…kActionService.js:2
o @ chrome-extension://p…kActionService.js:2
_sendEnvelope @ chrome-extension://p…kActionService.js:2
_flushOutcomes @ chrome-extension://p…kActionService.js:2
guidde.js:2
add @ guidde.js:2
o @ guidde.js:2
t @ guidde.js:2
t @ guidde.js:2
guidde.js:2
add @ guidde.js:2
o @ guidde.js:2
t @ guidde.js:2
t @ guidde.js:2
Any help for a resolution would be appreciated.
