This is the first time using Coda, so the question might be a silly one
The thing is that I created a Coda doc with a table to host information about books. I would like to give people the opportunity to add new books by title + author and then use Zapier to automatically connect to Google Docs via webhook and retrieve additional data such as publication date and the bookcover.
For this, I have create a new API Token using the document link. [1]
Then I went to Zapier and connected to my account, added the token from Coda and started creating the Zap [2]
When I want to select the Document and Table, however, Zapier throws the following errors: [3]
Weâre having trouble loading âDocumentâ data
Could anyone point me to what I might be missing or doing wrong?
Hey Marc - welcome to the community. Thank you for posting your question here!
Based on your first screenshot (of the Coda API token), I believe the issue is being caused by the fact that your token is doc-specific. While tokens are typically limited to reading/writing data to a single document or table, Zapier is unique and requires access to all of your documents. Therefore, youâll need to create a new API token with no restrictions (in other words, doesnât point to a specific doc) to solve this issue. You can create a new token at coda.io/account. Your new token should look similar to the one in my screenshot (note that the âDoc or table to grant access toâ field is left blank).
