Adjusting the width of a Text Control
A simple question. When I add a Text Control to a document, is there a means of adjusting the width of it? The problem is that the placeholder text is too long to display fully and I’d like to expand the width to show the full text.
Cheers!
That cannot be done yet, I have asked coda to allow for some of these type of changes while it was in beta.
Cheers for the reply @joost_mineur. At least I can relax and know it’s not me :smiley:
I’ve moved this thread to a better home now (suggestion box)
bump as this is a feature I would love to see for templates for two reasons:
  1. When using Coda to create a consultation form, viewing the doc on the Coda app on an iPad allows easy entry of data into the text field
  2. It enables you to programmatically reference that data elsewhere (whereas just plain text doesn’t)
Community members - please add your likes if you would like this feature too :smiley:
I’d definitely be eager to see this, as well. Right now, the UX for the text control is pretty awful when dealing with anything other than very short bits of text. Would be great to have a multiline option, as well as the ability to have a validation formula, as one can do with forms.
+1
Asking for this as a “Feature” is being pretty generous. The textbox feature is basically unusable like this, at least for me.
Please add my vote for this feature.
+1 from me to fix this too. :slight_smile:
Yes please add the ability to specify the width of input control. thanks
+1 – seems easy enough and dramatically increases the use of forms for virtual collaboration and consulting
+1 - I’ve been using Coda more as a lightweight app development system and while the row-detail pages and forms could probably be hacked to help with something like this, seems like it would be a fairly straightforward modification.
Any update on this request?
Bump. Are there any updates on this?
This in combination with hideable input fields would open a lot of interesting use cases.
+1
“Asking for this as a “Feature” is being pretty generous. The textbox feature is basically unusable like this, at least for me.”
That is exactly how I feel, how did this get prioritized development time and survive any degree of testing/feedback. 150 characters width is not usable.
The small size of the Text Control is often inconvenient and I’m forced to create helper tables instead.
Maybe adjusting the width in pixels would be too granular and not aligned with the Coda way, but what about some presets like ‘Full line’ or ‘Paragraph’?
for what its worth you can get wider and higher text input widgets on the page.
just create an ai block, but dont give it a prompt.
give it a name.
then you can resize it and use it as a text input box.
in a formula you can get its contents by refering to it by name
that’s a nice trick, thanks Max!
Bump. any updates and ears for this from coda devs? (speaking for coda makers)
+1 to this one.
I do appreciate the trick with using an Ai field, but I would rather see options to actually adjust the size of the textfield, also including multiline…
+1 to this one.
This will bring more harmony to the page
