Trying to build a small workflow app to make a marketing UTM creator. However, the text input control is ridiculously short with no way of making it wider. Is there a workaround?
Hi Trevin!
At the moment there is not a way to lengthen a text control (this has been requested before and we are working on rolling this out in the future.)
A workaround for this would be to have a 1 row table with 1 column where you could adjust the width and use buttons or formulas to get the same functionality you are looking to get with the text control.
If you want any guidance or any additional help on your doc feel free to schedule some time with the Coda Success Team Here
