Automation If Condition with Date Column Fails, but Works in Formula – Need Both Auto and Manual Checkbox Control
Hi Coda Community,
I’m having trouble with automations involving two columns in my table:
  • Recording Date (type: Date): This column stores the relevant date for each item.
Recording done (type: Checkbox): This column should be checked automatically if the Recording Date is before today, but I also want the flexibility to manually check or uncheck it as needed.
Here’s what’s happening:
  • If I use [Recording Date] < Today() as a formula in the “Recording done” column, it works perfectly—but the checkbox becomes read-only and I lose manual control.
  • If I try to use the same logic in an automation (trigger: Row changed on Recording Date, If: [Step 1 Result].[Recording Date] < Today()), the condition always returns false—even when the Recording Date is before today.
  • If I set the If condition to just true, the automation runs, but does not update the checkbox value.
My goal:
I want “Recording done” to be automatically checked if “Recording Date” is before today, but I also want to be able to manually check or uncheck the box if needed (so a formula-only solution isn’t enough).
What I’ve tried:
  • Verified both columns are correct types (Date and Checkbox)
  • Tested with new and existing row
  • The formula logic works in a column, but not in the automation If step
Is there a workaround for this? Any advice to achieve both auto and manual control would be greatly appreciated!
Thank you!
:waving_hand: @Takshika_Jambhule
welcome to the community! :hugs:
this thread addresses the same issue and provides theory in solution
hope this helps!
Cheers!
Mel
Thank you for the suggesstion. However, We used “Button” option to tackle this time :slight_smile:
