Is it possible to have a column where the data appears at the bottom of each cell (bottom alignment) instead of at the top of each cell (top alignment)?
Many thanks, Gregg
Hey @Gregg_Stebben ,
No, Coda does not have formatting features to accomplish that.
FWIW I found a hack that accomplished two things:
- When using arrow to go down to next row, get the full row on the screen
- Get text to bottom of cell
It’s obvious really: I created a column with a lot of hard returns, and put the text I wanted on the last row. In this case, the text at the bottom of the row is the name of the index row, so that when I move down to the next row it always fills my laptop screen and I can also see the value of the previous index row above for reference.
