I have two columns with the same formula, one of them is aligning the content to the top, and the other is aligning to the bottom. They are both ‘text type’ columns:
This is difficult for us to test if you’re overriding CSS. Does this do the same thing without anything overriding the styling?
I turned off my CSS override before making this post. I just opened in Safari and I’m getting both aligned bottom:
Can you share an example doc so we can know how to recreate this?
Yes @Ben_Lee I just enabled ‘Share with Coda Support’ - do I need to do anything else to get it to you?
If you can open a support ticket using the “?” icon, paste the link there and add “Send to Ben”, that would be great. They’ll assign it to me when it comes in and I’ll try to re-create this.
I was able to re-create this. I’ll get it submitted.
Thank you for promptly helping me @Ben_Lee
@Ben_Lee this bug appears to be fixed!
Yep, the bug fix just hit the servers!
Glad it’s working!
