Business OS Template (All Activities not working)
Hi! Can anyone help with figuring out why–after copying the doc to my account–I can’t add a new row here (Engage · Business OS) @John_Coda @John_Scrugham
Hey @d_y, Actually, it looks like the issue is because the column type is set to Text rather than a Relation on the All Activities table. Changing the column type should fix the issue! We’ll also look into fixing the template, thanks for flagging.
thanks @Jasmine_B . Could you make a video play by play, like with the instructions on how to execute what you’re describing? I would appreciate that sooooooooo much :slight_smile:
example
