Similarly to how most data types can act as both representations of a manual input and a formulaic output, does the same apply to sliders? Can I have a formula output a decimal number between say 0 and 1, change the column type to NumberSlider, and have the slider position reflect the relative value of this number in the unit interval [0; 1]?
I can’t seem to find an obvious way to do this. Changing the column type to Number > Percent does seem to work and indicate this value in the unit interval as a percentage.
Hi @louca.developer ,
far from being a proper answer to this, I realised I wanted a similar feature, too.
Starting from the “old” trick posted by @Paul_Danyliuk (MEGA TRICK: SVG in Coda (one step away from generated charts and mind maps!)) and subsequent implementations, I built up a very basic SVG slider:
I hope this might be a temporary workaround or at least a starting point to play around.
The good part is that you can add a more fine-grained set of configurations (I just provided the basic ones)
Cheers!
@Federico_Stefanato the SVG slider looks nice but I’m not sure why you had to do it at all?
@louca.developer A slider column can also be a formula column. However a slider will always show a numeric value — there’s no way to force it to show percent.
You can either:
- Make a slider in range from 0 to 1 with increment e.g. 0.01 and have absolute values there. E.g., 0.4 would mean 40%
- Make a slider in range from 0 to 100 with increment 1 but in your formula multiply your percent value by 100.
- Or yeah, go with a custom SVG drawing or a Rectangle-based progressbar-like representation.
