Conditions / Preassigned values on slider
Hello All,
Thank you in advance for looking into my question.
I am currently managing different tasks and resources and I thought that using sliders as part of the task monitoring would provide an extra visibility on the overall progress.
So far I only played with Status (Not started, in progress, on hold, cancelled, completed).
I am trying to link the status with a slider. Not sure yet which one should modify the other but I thought the status would allow to do the following:
  • Not started = slider at 0 and not possible to modify
  • In progress = slider can be modified with whatever value you want to assign
  • On hold = keeps the current value but slider cannot be modified
  • Cancelled = I guess it would be like “On hold”
  • Completed = slider at 100 and not possible to modify.
I cannot get the formula to work therefore your help would greatly appreciated.
Thanks again
Hi @Johan_Bertin ,
and welcome to Coda Community! :handshake:
Unfortunately you can’t “disable” an input field.
You can disable a button or provide a formula-based value/control (preventing it to be manually changed), but not mixing manual input and formula-based in the same column.
As a basic workaround I would:
  • add a “twin” slider column formula-based reporting the slider value (therefore, read-only)
  • filter a view with only editable tasks (status = in progress) showing the editable slider
  • on the other filtered views (status != in progress) showing the non editable one.
I hope this helps.
Cheers!
Hello @Federico_Stefanato
Thank you for you quick reply. Then the deactivation would not be the main feature.
I am more concerned about the possibility to set a custom value when the in progress is selected and a custom one for not started and completed.
Thank you again :pray: :smiley:
Hi @Johan_Bertin
I understand.
I think it’s a design perspective relying on how you wish to shape your application.
The two main ways could be:
  • your interface is mainly action-based; i.e. the change of a status is through a button.
    • pros: full control of the operations triggered by buttons and data consistency potentially higher
    • cons: higher complexity in the maintenance because is full formula based in the button(s) and careful filtering out of the columns affected by button(s)’ actions.
  • you check - and fix - consistency discrepancies on a scheduled automation; i.e. at row-changes or predefined intervals you run an automation that “puts back” discrepancy values for statuses that have default ones.
    • pros: less overall complexity in the row design
    • cons: might create a counterintuitive and deferred perception form a UX perspective (e.g. I change something that changes back…)
You can also add some visual features (conditional formatting) or notifications (again or row change or scheduled) warning the users for the inconsistencies.
Lastly, I believe that (for internal tool) some good discipline and habit are the best rules ever and keep the document light and flexible and the responsibility high… :slight_smile:
Let me know what you think about it.
Cheers!
you are actually right.
I will perform the following then:
  • Default value set up to not started and slider at 0 when a new row is created
  • When changed to in progress, I will adjust the value of the slider accordingly
  • To complete a task, I will create a button to change all the status to completed and slider at 100
Easier to manage and maintain the consistency of my document.
Thanks a lot for time you spent !
Always a pleasure! :slight_smile:
Enjoy!
