Coda Sync from documents
I have coda document a, with a table called projects.
I have synced the projects table from document a to document b.
In document b I want to have a table that looks up the projects that are synced in from document a.
It doesn’t seem like there is a way to do this?
Hi Erik,
Could you expand your explanation? It is not clear to me what you want to do. Your request appears tautological.
P
I was using the sync, not the cross doc. Figured it out. Thanks
