Connecting tables across different Coda docs
I copied and pasted a table from one Coda doc (that table is connected to a master table in the doc) and put it in another separate doc. Since doing that, I’m realizing the data is not carrying over (obviously because this duplicate table is not connected to the same mater table). I’m having a hard time figuring out if it’s possible to make that connection between the original table’s master doc and this duplicate table so the data automatically updates! Thank you!
Hi Jessella,
Welcome to the community!
There are several way for syncing data across documents. The most basic ones are here: Syncing data in and out of Coda, Coda sync guide | Guides
It sounds like Cross Docs would be a good fit for you, but would need to know more about your use-case to tell for sure.
Hope this helps,
Pablo
