Color conditional formmating in formula
Searching the forum I found the undocumented function _Color.
Has anyone used this before? I’m unable to get any color change with it.
For example, if a value is less then 4 I would like the text to be red.
I have tried both of these but the text color does not change.
SwitchIf(Average([Work-Life].[Work-Life]) < 4, _Color("red", Average([Work-Life].[Work-Life])))
SwitchIf(Average([Work-Life].[Work-Life]) < 4, _Color("#ff0000", Average([Work-Life].[Work-Life])))
Interesting. I use it in every single doc I make. Mostly to color button text
_color(“#628dbd”, “text”) is my personal favorite.
The only thing I’ve noticed is that it doesn’t always reliably work on non-text values. So make sure to use toText() if the value you are attempting to Color is a date or something.
Thank you. That explained it.
It was a number. I used ToText and it is working correctly.
