Setting Background Color with a Formula..._COLOR?
Coda changed how the _COLOR function works. Is there anyway to set the background/highlight color of text using the _COLOR or another formula?
Thanks
How did they change the way it works?
Im still seeing it work the same as always
A while back the first argument followed this format “kr-[color name]-[light/medium/dark]-[fg/bg]”
So you could set the background color of the text using the “bg” at the end of the color name like: “kr-Blue-light-bg”. But now the color name is either hex or a list of colors like “Blue” and doesn’t seem to allow to set the background color.
Anyone to set the background text color dynamically like this?
Can the _highlight() formula accomplish the same thing for you?
