Hello!
I know this is a long shot. But is there a way to combine multiple PDFs within Coda? Lets say I have the table below:
Then I could click a button to merge FileOne & FileTwo into MergedFile. Basically something like what Adobe Acrobat Pro does.
hi @Samuel_Langford , nope you cannot in Coda. It is not even possible to access each PDF with AI.
cheers, Christiaan
@Rickard_Abraham werent you working on something like this at a point? Did you ever get it working?
You can definitely do it with a custom pack . . .
Thanks for tagging me! You’re right, and yeah it worked fairly well
However, today I had a bit of a breakthrough with PDFs in general!
I launched a new custom pack which should make merging PDFs in this case a breeze!
Jannis
5
Very nice, appreciate the work @Rickard_Abraham.
Sincerely
Jannis
