I am trying to create a table that updates from a master table using Cross-docs. The table updates just fine, but the comments in the comment section does not transfer over. Is there a way to do this??
Hi Jerod,
From what I know, cross-doc does not support transfer of comments. Only cell values can be transferred.
This would be helpful to sync the comments. We have a table that is read-only (cross doc) but want to engage in discussion; however those comments should reside with the āmasterā table. Is there a workaround?
Cross-doc comments sync is very needed feature. When could we expect an update. Or at least a formula, that could pull comments.
Iāve developed a solution to run projects and tasks through Coda for my creative agency, utilizing one ācontrol centerā doc and then unique, project-specific docs filtered by our project codes. Itās been a great solution overall, except that weāve discovered comments donāt carry through in a sync.
Comments are getting lost, and this single missing feature will effectively kill my attempt to overhaul our workflow and replace Asana.
Yeah, I also hate that comments are not synced with cross-docs.
What you can do is disable the native comments and build your own commenting system with one/several tables, that you can make visible in all the relevant detail views and keep them synced across documents.
For example, in this post I created a simple commenting system
It will never be so nicely integrated as the native solution, but you have the power of coda to customize it and taylor it to your needs just like any other table.
Hope this helps,
Pablo
I actually just resolved this problem, kind of by accident. Iām thrilled, shocked - all of the above.
Iāve always been syncing tables in cross-doc syncs. You can sync entire pages, and if you do that it will carry through comments.
If you donāt need to secure the data, syncing pages is a very good option.
Glad you found something that works for you!
True, but then you canāt use buttons unless everyone has access to the source doc
exactly it would help a lot!!!![]()
I imagine how it hurts(( I faced the same frustration with my expectations. @Ryan_Polomsky have you found the alternative solution to share comments?
