Conditional formatting - not working when displayed by a formula
I have a table called Gender that uses conditional formatting (please forgive the stereotypical colors for F and M!):
I have a table called Student Extended Data that has a field called Gender that uses the Gender table as a Lookup table. The conditional formatting from the Gender table comes accross perfectly:
Finally, I have a table called Student Master that uses a formula to pull the Gender from the Student Extended Data for each student: [Student Extended Data].filter(thisRow.[Student Number]=[Student Number]).Gender
For some reason, when the gender is displayed by the formula, the original conditional formatting is not displayed:
Is there any way to get the formatting to come accross with the formula? Or do I have to recreate all the conditional formatting again and apply it to the formula field?
Hi David,
Is the gender column of type Lookup? The styling should carry through if it’s a lookup type column.
A workaround that can be a little more performant is to simply color the text in the cell itself instead of using conditional formatting. This styling should carry through regardless of where it is used.
If a formula like you posted returns a row value, which it does there, I prefer to leave it as a text column type. When you make it a lookup type, the formula calculates that row value, then the lookup type looks to find the row match, which is extra work. On a big table you can start to notice this lag in calculation time.
Hi @Ben_Lee, thanks so much for your reply. I didn’t realize that a field with a formula could be of type Lookup. I thought it was type “Formula”, which I guess doesn’t really exist as a “type”! As soon as I switched them to Lookup, they performed as expected. Yay!
I’ll have to keep an eye on speed. If I find that things are getting slow, I’ll try your workaround.
Thank you!
David
Hey Ben, Can I ask for clarification on this? It might be important for other projects.
So when I change the column type to “Lookup”, what does it mean that the formula “calculates that row value” and looks for a match? Does that mean if my formula fetches a row (or rows) from a table, the column type will go looking for those rows again to fetch the conditional formatting?
Thanks for your insight!
