Is there a way to connect a google form to a document?
I have a form I created that allows people to submit work orders but I want to use Coda to keep track of the submitted work ordered progress.
Is there a way to do something similar straight from a Coda doc? Currently not everyone in our organization is connected to Coda.
Any suggestions would be appreciated.
Hello!
Maybe Integromat will help you?
you can use Zapier to connect Google forms with Coda.
Can confirm I use Zapier to connect a Google form to a Coda doc to manage our customer returns.
The zap is looking for new lines on the GSheet that gathers the results then transfers this line into a table in Coda.
If you plan to manipulate the data further, I suggest using an automation in Coda to link the new data to a 2nd table. That way you keep a 1 to 1 copy of the Gsheet in Coda and you have the 2nd table for processing/manipulating the data.
Thank you all for the help
I found Zapier after posting my question and it seems like it is a good fit. I like the idea of having the table duplicated though, hadn’t though of that previously, but its a smart idea.
Hey Caleb, Arpit from Integromat here. You can do this (and a lot more) using Integromat’s Coda App. Happy to help if you still need it!
Arpit, I’m curious as to whether Integromat could keep something like Google Forms/Sheets and Coda in more of a 2-way sync situation. I’m needing for clients to add more information via one form link they can return to that would then add to or even change a cell on the table row. Is this possible too?
Yup, I’m using Integromat for the exact same thing.
Absolutely Matthew, this is a common use case and very much possible with the Coda app on Integromat. If you have questions specific to Integromat, you may post them on our Facebook community too: intm.at/community
Would be great to include the google form directly in coda. Any plans for this @Krunal_Sheth
