How to Connect Coda with Slack or Google Sheets
Hi everyone, My name is Soumitra Dutta, an Oxford-based entrepreneur & photographer. I’m currently exploring ways to connect Coda with Slack or Google Sheets to improve workflow automation. Any suggestions or resources would be really helpful.
Regards
Soumitra Dutta
Welcome!
There are two common ways that people integrate Coda with other platforms:
(1) Packs
You can install the Google Sheets Pack or Slack Pack in your doc, to enable 2-way communication between Coda and these services. Typical ways that Packs integrate include pulling in data as a table from other sources, accessing data from the outside service in a formula, or pushing data out to the other service (e.g. sending a Slack message)
(2) Workflow automation platforms
You can also use platforms like Zapier, Make, or N8N to communicate between Coda and other services.
Are there any workflows you have in mind in particular?
