@mallika, as you can see in the image below, the rather easy formula .day() returns not today (in my timezone), but yesterday. I have checked my timezone (Brussels). Is there a way one can solve this?
What worries me is that I am not the first one to report, already in 2018 this bug showed up.
to make it even more interesting
I do not have confidence in the Trick Column that gives back the right number, it may work out against me in the hours to follow.
@Krunal_Sheth, Your input will be much appreciated, as it’s a quite hot topic.
thanks for your attention, best from sunny Belgium, Christiaan
Dear @Christiaan_Huizer,
Is there an option to share a copy of your doc?
Yeah, please do share your doc. I can imagine three things:
- Timezone issues
- The date having some time part to it actually (it’s not shown because of format, but it may still be there in the value, since all date/time/datetime values are stored as timestamps)
- Floating point issues — however the values should have no decimal part if it’s only the date and no time (12 AM is
.0)
Okay, I noticed what’s wrong.
You’re using a Date format here, aren’t you?
.Day() returns a number, not a date. The column format should be Number.
What you see is the integer number getting evaluated as Date (number of days since 1/1/1900 12 AM UTC+0)
then just showing the Day of that converted date.
yes, this is it. thanks @Paul_Danyliuk
since I was working with a day, I assumed that a date format would be the way to go.
thanks a lot!
