Emailing unique generated emails / Personality test
Hey,
I am trying to setup a personality test. Through a form people submit response (and their email). I calculate a category for them (add a row to a table with name, score and category) and then want to send them the results.
How do I get the template to include unique items - such as name, score based on the response?
When I include a variable from a table in the text, does send this through email limit the response to the one individual response of the person?
Any help would be super appreciated.
Dear @Marlin_Watling,
Not sure if I understood your point, some sample of the expected outcome is a better way to show your expectations.
Maybe this post contains some inspiration: (Credits: @Ben_Lee )
Dear @Jean_Pierre_Traets,
Sure. More details are here:
This is where the data comes in:
A survey brings in data and calculates a score (High-Score and percentage). Once a row is added, I want to send a text based on the group (out of 5 possible). So, I select text 4 and want to include the name, the score and the date.
How can I get it to select only the relevant data for the row and send that information in an email?
Dear @Marlin_Watling ,
What you are missing is the option to select the instance to be able to filter out only one row of your table [Survey Key Data]
And when filtering to make the “email” = select 1, you will get only the particular row results
Great! That works.
Can I do that selection directly from the table (key data)? Or is this only doable through the select list?
Of course you can do that, the select list gives you the benefit that you don’t have to write the whole formula for each of the rows in the [Survey Key Data] table.
