Feature Request - Indirect
Really enjoying Coda! One suggestion I’d like to add is something equivalent to INDIRECT in Excel and/or Sheets.
For an example use case, I have multiple tables in the same document referencing each other. This forces tables to have to be done like the table on top instead of the one at the bottom:
Being able to refer to the name of a column and use it in a lookup and/or filter would be great.
Now, you can sort of force the below table by using Groups - i.e. grouping the Weeks along the top and the Persons along the left, as follows:
While that is a good workaround, still think Indirect could be useful in a number of areas.
Thanks in advance for any consideration.
Edit: Grammar
I would appreciate this feature. But the power of indirect isn’t just for dynamically choosing the column name, but also the table name.
This would allow a table column to reference data from not just a fixed table, but dynamically choose the table based on another column.
This allows much more flexibility in the data model space.
Example
table_car
ID, Desc
1, Honda Civic
2, Nissan Rogue
table_house
1,123 Newport Road
2, 457 Glenwood Street
table_owns
ID, person, thing_type, thing
1, Steve, table_car, Honda Civic
2, Victor, table_house, 457 Glenwood Street
See [How to dynamically choose table to lookup from?](http://How to dynamically choose table to lookup from? )
-Mark
