Filter a multi-select column by a multi-select control?
In reference to @harisiva 's comments and linked doc in this post: Filtering a table using a select list, but wanting an "All" option
Is it possible to filter a table on a multi-select column using a multi-select control? None of my attempts are functional enough to even post here, but here’s a screenshot of what I’m trying to do:
“MultiFruitMultiSelect” is the control name.
@Ander - what would you want the results to be here say you chose Apple + Banana in the control. Should it show all rows that have Apple or Banana or Apple and Banana Only or Contain Apple and Banana.
@mallika All rows that contain apple or banana.
In the screenshot, that would be rows 2,3,4,5.
Hmm, that works from me - can you share your multiselect (column and control) setup please.
Fixed, thanks.
The control was pulling from [Fruits - 2] instead of from [Fruits - multi].
