Filter Multi-Select column based on Select Control
I have a table base on seasons and years, I want to filter for a year’s (12 months) work of data based on a select control.
For example:
Select Control = Winter 378 – the view should show data for Winter 378, Autumn 378, Summer 378, Spring 378
Or
Select Control = Summer 378 – the view should show data for Sumer 378, Spring 378, Winter 377, Autumn 377
To achieve this I’ve created a calendar table for each of the year/seasons and created a multi-select column (Calendar Range) where I’ve defined which Select Control (Header Date) results should result in that season/year being filtered.
I have tried:
Calendar Range.filter(Header Date)
Header Date.in (Calendar Range)
Calendar Range.in (Header Date)
Calendar Range.contains(Header Date)
And no results are found
What am I missing?
Thanks guys
Welcome to the community!
I don’t know your control name, but it seems like
calendar range.contains(select control)
should work.
@Martyn_Thomas
Something like this?
Looks like that sorted it - thanks so much guys
