Filter Control contents
I have a table that lists people’s attendance by month and by class.
The table is filtered by Class
I have a filter control on the month, so i can select a month to see the people who were in the table-filtered class.
However the filter control contains months that are not part of the table-filter (months that only contain classes that are not in the table filter).
How can i filter the filter-control to only contain the months i need/want?
Thanks
Dear @Martyn_Thomas,
When I get your question right, just make a new column with the formula MonthName(date) and assign your control to this column.
To example a little better
I have a table that lists students
If i filter the table by Class A - there is only data for months January and August
If i create an interactive control/filter by Month - the drop down also contains November
I want the control to only contain August and January (the months relevant to the table filter)
How can I filter/add extra controls to a filter control so it only contains the options that i want/relevant to the task
Have a play with the example here: https://coda.io/d/Community-Example_dOC-AN8k3Kj/_suoZM
This is not exactly what you were looking for but if you use a second interactive filter to filter your field Class then it is possible to compare both interactive filters and get the Month for the selected Class :slight_smile:
The formula in the interactive filter for the Month is then this one :
Filter(Students,Class.Matches([Select Students Class])).Month.Unique().Sort()
There’s another option too if you don’t want to use an interactive filter for the Class field :slight_smile:
You can also create a simple multi-select on the canva which will simply pull out the selectable items from the field Class :
and then using the same principle as above, filter your Month select list by the letter selected in the selected previously created :slight_smile:
Hope this help :slight_smile:
Edit : As I made some mistakes : a corrected test doc is available below :slight_smile:
I’m getting back here because I’ve made a mistake about this yesterday :upside_down_face: .
While creating those examples, it’s seems that I had some troubles copying/pasting things for some unknown reasons (Sorry @Martyn_Thomas)
Here is a corrected test doc for the possibilities in my previous post :slight_smile:
