Formula to push a button
Hi
Can we have a formula to push a button in a row?
For example I have task table where one of the column is a Donebutton, a Start timer and Stop Timer and I want the Done to automatically close the timer as well, which means pushing the Stop Timer among other things it’s supposed to do.
I cannot quite find a formula that does it, any help?
Hi @Chen_Zhong :blush: ,
There’s no “push button” formula because you just need to reference the button you want to push as an action in your button formula :innocent:
E.g.:
Let’s say I have a button doing something … and I also want it to push another button all I need to do is wrap the “principal action” and the “name” of the button I want to be pushed in a RunActions() :blush:
In the sample you’ll find below, I’ve created 2 buttons.
The first one, is the one doing what you’re looking for and it’s Action formula looks just like this :
RunActions(
  ModifyRows(
    thisRow,
    thisRow.[+1 (Button 1)],
    thisRow.[+1 (Button 1)] + 1
  thisRow.[Pushed Button 2]
What it does is just add + 1 to the value of the column called [+1 (Button 1)] and then push a second button called [Pushed Button 2] :blush:
The [Pushed Button 2] also just add + 1 in another column :blush:
This doesn’t answer fully your question (I mean, regarding your actual setup), but I hope this helps :innocent:
Thanks! Problem solved!
