I’m using @Al_Chen_Coda’s “GTD To-Do List with Gmail, GCal” template, but the items I add into capture only appear in the Views pages when I manually check the item as completed and then uncheck it to “activate” the box for the filter. In the pic below the first 3 rows I did this to (darker grey square) but the 4 below I didn’t (lighter grey). If I filter for unchecked only rows 1-2 will appear, while 4-7 disappear. Even though they’re unchecked the box hasn’t been “activated” yet.
Please help! It’s making the template functionally unusable.
This should be the default setting for the checkbox column, but if you switch to formula view, then delete the formula, it can be deleted. Older docs may have this blank from before the default was added too.
Copy/Paste can also work for bulk updating a column of “unchecked” boxes, just copy one of the value that’s working and paste that for the rest of the column to get caught up after making the new row value change.
