Help with mobile "add row" button not working on mobile?
Hello Everyone, Thanks for any help at all. We’ve created a time keeping doc, and our mobile page “add row” button, will not work. It just spins and spins. It works perfectly on our desktop. I feel like I am missing something very simple. Any help would be greatly appreciated. Thanks
:waving_hand: @Jef_Forward
welcome to the community ! :hugs:
is your time keeping doc a large doc? does it show “calculating“ in the mobile app?
generally have found if the doc is more on the smallish size, adding a row to a table via a canvas button isnt an issue.
to be frank - the mobile app is at the mo lackluster at best.
The good news is there will be a mobile app roundtable later this month as per
so fingers crossed some movements in this field will be actualized this year :crossed_fingers:
hope this helps!
cheers!
Mel
Mel! Thank you, and yes, it does show “calculating” in the mobile app. So, I guess that confirms I built it too big. I wonder what the triggers determine that. I didn’t think it was a large doc. Thanks for the update on the roundtable - I am very interested in that. AND YES, fingers crossed. :slight_smile:
The good news is that I found a work around, although inconvenient. I deleted the app, and opened my phone browser, and went to coda.io website, my doc and specifically my “mobile page”, and then hit the share and “add to home screen” and viola, I have a button on my phone that opens directly to my mobile designed page. Now my challenge will be figuring out the work flow for my 22 mobile users to get this on their phones. Cheers and thank you! Jef
