Hidden fields show - and unhidden field don't) in expanded view
Good morning,
Just noticed that when I expand a view, is shows fields that should be hidden (and are hidden in row or card layout), and some other fields don’t show, while they are not hidden.
Only some fields are affected, most fields show as expected, but when you expand a card to do some editing, you should have all the unhidden fields, and preferably in the same sequence as on the card or in a table row.
I double checked which fields should be hidden, I don’t think I made mistakes on that end.
Greetings,
Joost
Hi @joost_mineur,
I think this is expected if you’ve edited the expanded layout. I’m testing on a table and when the expanded view is set to “Default” for the layout, the hidden verses non-hidden columns in the table are respected in the expanded view as well. Even changing them after the fact.
@Ben_Lee
Thank you for your reply to my post - where or how do I set the expanded layout to ‘default’?
@Ben_Lee
Oh - excuse me. I figured it out - unlocked my page and reset layout to default. I can’t remember having set that any different, but I have ‘set’ just about everything over the past couple of months, so I am sure this has been changed by me sometime or another.
I am fixing this now - thanks for helping me to go in the right direction.
Greetings,
Joost
