Hide columns with a button
Hi everyone,
is there a way to hide columns in a row with a button trigger based on the value of another field in the table ?
No Sadly - You really can’t work with columns in a formulaic way. You can’t hide/unhide them with an action, they can’t hold dynamic names, etc.
What are you trying to accomplish? If you share more of your use case there might be other ways to accomplish what you are looking to do!
Thank you! I would like to have two invoice templates, one with discount and one without. I found a solution by creating 2 templates and with an if to choose which template to display. works. Thank you.
I have the exact same problem as well! would be great if someone has a work around!
