Hide/Unhide a specific column with a button
Hello,
Is there a way to hide/unhide a column or group of columns using a button?
I tried to search for formulas that would change this property but I had no luck.
I’m trying to create a voting table where the votes are “secret”.
hi @Mauricio_Avalos
Nope this is not (yet?) possible.
The creation, deletion or hiding of a column is not possible using a button or an automation, but it would be great to have this in our toolbox.
Cheers, Christiaan
This would be a massive game-changer to hide\unhide columns in any view - table, detail, chart. That would open whole other universe of UX and UI.
I’ll +1 this feature request. This would significantly reduce the number of views we need to create. It would save us a lot of time if we could use a button to switch between different lenses depending on the task we’re working on.
